Shop & Explore
Olight ArkPro Series – Flat Unibody EDC Flashlight with Multi-Light Sources
- 4 Lights,7 Configurations: As an upgraded version of Arkfeld Pro, the ArkPro flashlight is equipped with a 1,500-lumen floodlight for broad-area lighting, an 800-lumen long-range spotlight (205m reach), a powerful UV light, and a green beam. The green beam features independent control and combines freely with the three light sources—ideal for outdoor adventures, work, and emergencies.
- Perfectly Pocket-Sized: The flat design fits so comfortably in your pocket that you'll barely notice it. ArkPro EDC flashlight is built for you to travel light and move freely.
- Style-Perfected Control: A bold central ridge adds visual depth and balance, with a textured side surface ensuring secure control. Its concave buttons offer ergonomic ease of use. Enhancing versatility, a dual-direction clip clamps tightly to shirts, pockets, or hats for hands-free use, while the built-in magnetic base attaches effortlessly to metal surfaces—boosting adaptability in more scenarios.
- Easy Charging & Operation: ArkPro's dual charging via USB-C and Magnetic Dock breaks through traditional constraints, easily switching between the three lighting modes using the intuitive circular selector with a dedicated green beam button for flexible use.
- Clear Status Indicators: Includes color-coded indicators for straightforward distinction: white for brightness levels, green for battery status. ArkPro flat flashlight also features a lockout indicator that clearly shows when in lock mode, ensuring you stay informed of the flashlight's status at all times.
$179.99
