Olight Marauder Mini Powerful LED Flashlight
●Smaller in size, yet powerful: A smaller size than the previous Marauder series flashlights but with all power and function.
●Dual-beam with flood and spot: Features a 600-meter round spotlight beam from the central LED and a 7,000 lumens floodlight beam from 9 surrounding LEDs.
●Uniformly distributed RGB color LEDs: Three RGB color LEDs are uniformly distributed around the converging lens, making it suitable for use during any occasion.
●Easy toggle switch & 3D rotary knob switch operation: A simple toggle switch to select either spotlight or floodlight; an intuitive rotary knob switch to activate the light and circle through 7 output levels. (Note: Rotate the knob switch quickly over 90 degrees to unlock it)
●Safest in its class: A built-in thermal sensor and cooling fins to ensure safety in case of overheating and lens obstruction.
