Table of Contents 1. The Next Generation of Olight Baton Series Arrives in Canada 2. At a Glance – Key Specifications Comparison 3. Baton 4 Pro: The Balanced Everyday EDC Performer 4. Baton Ultra – Built for Extreme Outdoor Performance 5. Shared Features – What Makes Both Baton Models Stand Out 6. Which One Should You Choose? 7. Final Verdict – Upgrade Your EDC Lighting for Canadian Conditions 8. Everything You Need to Know About the New Baton Series(FAQ)
The 2026 debut of the Olight Baton series marks a significant advancement in compact lighting technology. Designed for the rugged environments found across Canada, from the urban streets of Toronto to the dense wilderness of the Rockies, the Baton 4 Pro and Baton Ultra offer professional-grade performance in a pocket-sized form factor. These models represent a shift toward high-efficiency LED technology and innovative materials, ensuring that outdoor adventure enthusiasts and professionals have reliable illumination regardless of the conditions.
Both the Baton 4 Pro and Baton Ultra utilize the 18650 battery platform, balancing high capacity with a weight that remains manageable for everyday carry (EDC). As Canada experiences extreme seasonal variations, these flashlights are engineered to perform in cold temperatures and resist moisture with IPX8 waterproof ratings. This launch introduces specialized features like the OAL™ superalloy and the self-developed EIP 1 LED, setting a new benchmark for what a compact flashlight can achieve in 2026.
Selecting the right tool requires a clear understanding of technical capabilities. The following table provides a direct comparison of the primary specifications for both models, highlighting the performance upgrades in the latest generation.
| Feature | Baton 4 Pro | Baton Ultra |
| Max Output | 1,600 Lumens | 1,800 Lumens |
| Max Throw | 200 Meters (656 ft) | 300 Meters (984 ft) |
| Max Light Intensity | 10,000 Candela | 22,500 Candela |
| Body Material | 6061 Aluminum Alloy | OAL™ (O-Aluminum) Superalloy |
| LED Type | High Performance LED | Olight Self-developed EIP 1 LED |
| Weight (Incl. Battery) | 115 g (4.06 oz) | 115 g (4.06 oz) |
| Length | 111 mm (4.37 in) | 113 mm (4.45 in) |
| Battery | 3,500 mAh 18650 | 3,500 mAh 18650 |
| Charging Type | MCC3 Magnetic + USB-C | MCC3 Magnetic + USB-C |
| Runtime (Moon Mode) | 100 Days | 100 Days |
| Waterproof Rating | IPX8 | IPX8 |
The Baton 4 Pro serves as the quintessential EDC light for users who require a dependable, high-output tool for various tasks. It balances raw power with physical comfort, making it ideal for both professional work environments and home maintenance.
Compact Power with 1,600 Lumens Output
Equipped with a high-performance LED, the Baton 4 Pro delivers a maximum output of 1,600 lumens. This output level provides ample illumination for dark alleyways, large storage rooms, or backyard security. The intermediate beam pattern is specifically tuned for versatility, offering a wide enough spill to light up your immediate surroundings while maintaining a focused hot spot that reaches up to 200 meters.
Enhanced Thermal Management for Stable Performance
One of the critical upgrades in the Baton 4 Pro is the improved thermal control system. Olight engineers this model to keep the surface temperature below 45°C, even during high-output operation. This ensures that the user can maintain a firm grip without discomfort, extending the practical usability of the Turbo and High modes during intensive tasks.
Optimized for Everyday Carry (EDC)
Construction involves 6061 aluminum alloy, a material known for its excellent strength-to-weight ratio. The flashlight features a brand-new anti-slip knurling pattern. By combining shallow grooves with deep indentations, the Baton 4 Pro provides a premium tactile feel that remains secure even when wearing gloves or when hands are wet.
The Baton Ultra is engineered for those who push their equipment to the limit. It introduces proprietary technologies that enhance durability and light efficiency, targeting the needs of hikers, campers, and search-and-rescue enthusiasts.
Next-Gen EIP 1 LED Technology for Higher Efficiency
At the core of the Baton Ultra is Olight’s self-developed EIP 1 LED. This LED utilizes a non-uniform electrode design that increases luminous efficiency by approximately 10%. The result is an 1,800-lumen output that produces a crystal-clear, natural white beam, essential for distinguishing textures and colors in the Canadian backcountry.
Premium OAL™ Superalloy Construction for Maximum Durability
In a first for the Baton series, the Baton Ultra uses OAL™ (O-Aluminum) superalloy. This proprietary material offers superior hardness and scratch resistance compared to standard aluminum alloys, ensuring structural integrity through years of heavy use in environments involving rocks, ice, and metal tools.
Extended 300-Meter Beam Distance for Outdoor Exploration
While the Baton 4 Pro focuses on balanced illumination, the Baton Ultra emphasizes reach. With a maximum light intensity of 22,500 candela, it projects a beam up to 300 meters. This extended throw is vital for spotting trail markers at a distance or scanning across large lakes.
Both models in the new Baton series share a foundation of user-centric design and advanced power management specifically optimized for long-term reliability.
- Dual Switch System: Includes both a side switch for brightness levels and a textured tail switch for instant access to Turbo and High modes.
- Dual Charging Convenience: Support for both MCC3 magnetic charging and a hidden USB-C port under a rotating tailcap ring for universal compatibility.
- 100-Day Runtime: In Moonlight mode, both lights can run for up to 100 days, making them premier tools for emergency kits and survival bags.
Choosing between the Baton 4 Pro and the Baton Ultra depends on your primary environment and lighting requirements.
- Choose the Baton 4 Pro if: You prioritize a light that stays cool during prolonged use. It is the better choice for indoor professionals, mechanics, and general EDC users.
- Choose the Baton Ultra if: You are an outdoor enthusiast who needs maximum throw and superior scratch resistance for wilderness exploration.
Explore both models at the official store: Baton 4 Pro & Baton Ultra Compact Flashlight High Lumen.
The 2026 update to the Baton series brings significant value to the Canadian market. By offering refined EDC balance with the Baton 4 Pro and extreme outdoor performance with the Baton Ultra, Olight ensures there is a high-performance solution for every user. Whether you are prepping for a weekend in Algonquin Park or need a reliable tool for your daily commute, these new models deliver the power and reliability required for northern adventures.
Q1: What is the main difference between Baton 4 Pro and Baton Ultra?
The Baton Ultra offers higher brightness (1,800 lumens) and a longer beam (300m) using OAL™ superalloy. The Baton 4 Pro focuses on thermal management (staying under 45°C) and a balanced 1,600-lumen output for daily tasks.
Q2: Is USB-C magnetic charging supported on both models?
Yes, both models feature a "best of both worlds" charging system, supporting both the MCC3 magnetic cable and standard USB-C cables via a hidden port.
Q3: How durable are these flashlights in extreme weather?
Both are IPX8 waterproof (2m submersion) and built with high-strength alloys designed to withstand the cold Canadian climate and significant impacts.
Q4: What is EIP 1 LED technology?
EIP 1 is Olight's proprietary LED design that increases luminous efficiency by 10%, providing a brighter and more natural white beam than standard LEDs.
Q5: Which model is better for camping and hiking?
The Baton Ultra is the superior choice for outdoor activities due to its 300-meter reach and the rugged OAL™ superalloy body that resists scratches from gear and nature.
