When it comes to finding the right headlamp, most people can get confused as there is so much data to look at, lumens, runtime, beam throw distance and numerous brightness modes and various other features. You may go straight to the headlamp with the highest lumen count. However, it's a little more complicated than that. As the lumen count increases, run time decreases, and many headlights run at maximum lumens for only a few minutes or ten minutes before draining the battery. In fact, 300 lumens can handle most usage scenarios. We'll explain what terms like lumens, runtime, beam throw distance, and more mean, and we will test out Olight's headlights so you can make the most informed decision.
What is lumen
Lumen (lm) is the international unit used to measure luminous flux, which measures the total amount of light received by the human eye at different wavelengths per unit of time. In simple terms, lumen is used to describe the brightness or intensity produced by a light source, such as the brightness level of a lamp that can be measured in lumens. The higher the lumen number, the higher the brightness or intensity produced by the light source.
The lumen rating system has not been standardized in the past, which has led to many brands advertising false lumen numbers. Thankfully, brands today have standardized methods for measuring lumen levels.
Headlamps are now tested using standardized protocols to measure their performance in terms of total lumens, beam distance, durability, and battery life. This approach has successfully curbed misleading claims made by some manufacturers, forcing them to lower exaggerated ratings to more realistic levels. This change has strengthened consumers' trust in the products they purchase, while quality brands can better compete with knockoff brands.
Although lumen count is an important criteria to consider when purchasing a headlamp, it is not the only one. Most of the time, you won't need to use your headlamp at maximum brightness, as that would rapidly drain its battery. Therefore, it is crucial to find the right balance between lumen count, run time, and beam distance based on your specific use case. For example, two headlamps with the same lumen rating might offer vastly different lighting effects. One may provide broad, diffused light whereas another may project a narrow beam over a longer distance. These lights are technically similar but serve different purposes.
Recommended headlights for outdoor use
A headlamp with a general output of at least 300 lumens of flood beam is the most useful for any type of outdoor activity such as camping, running at night, hiking, or mountaineering. These headlamps can illuminate large areas, which is very practical when engaging in outdoor activities. The Olight Perun 2 Mini can fully meet your needs.
This product has several notable features that make it stand out in the market. First, despite its small size (comparable to a thumb), it boasts an impressive maximum output of 1,100 lumens. Additionally, it offers red light functionality, which provides optimal visibility without impairing your night vision and can be utilized as an emergency warning signal if needed.
The versatility of this product is another important factor to consider. It can be utilized as a handheld EDC flashlight or as a headlamp with the included upgraded headband. Moreover, its magnetic attachment feature allows the unit to attach to any iron surface, enabling it to function effectively as a work light.
To help users monitor the remaining power, the device comes equipped with a tri-color power indicator. This feature accurately displays three colors that correspond to different power levels: green for over 60%, orange for 60% to 10%, and red for 10% to 5%, with flashing red indicating below 5%.
Lastly, the product's upgraded headband improves user comfort by reducing the contact area between the headband and the skin. Magnetic charging is also offered and is facilitated with an included USB magnetic charging cable, providing an easy and fast way to recharge the device.
Recommended headlights for work use
Due to insufficient lighting conditions in the work environment, even your beloved work can become frustrating. If you often encounter shadows and low-light situations at construction sites, it may be time for a change. The bright light and durable structure of Perun 2 are ideal for your workplace, making it a safe choice.
The Perun 2 is a versatile device that offers a maximum output of 2,500 lumens. It can function as both a right-angle headlamp and a powerful EDC, making it a multifunctional tool suitable for various applications.
To prevent overheating when detecting nearby obstructions, the device comes equipped with a proximity sensor. This feature will automatically reduce the brightness and power off within one minute to ensure optimal safety during use.
The device also provides a hands-free experience thanks to its magnetic base feature. This allows the device to be attached to iron surfaces with ease, opening up further possibilities in terms of usage scenarios. The magnetic base is constructed with stainless steel, ensuring both durability and reliability in prolonged usage.
From June 12th to June 16th, special sale with up to 40% off.
VIP pre-sale: 6/12 (Monday) 20:00-6/14 (Wednesday) 20:00
For all users: 6/14 (Wednesday) 20:00-6/16 (Friday) 23:59
