Greetings, everyone! We are delighted to present to you three outstanding portable tactical flashlights: the Warrior 3S, Warrior Mini 2, and Warrior Mini 3. Whether you are venturing into a dimly lit forest or traversing city streets at nightfall, these portable tactical flashlights are specifically designed to deliver strong illumination and guarantee your safety. Join us as we delve into their remarkable features and exceptional performance, and uncover why they are an essential companion for any adventure enthusiast or tactical expert.
Data comparison
Warrior 3s | Warrior Mini 2 | Warrior Mini 3 | |
Beam Distance | 300 m | 220 m | 240 m |
Max Performance | 2,300 lumens | 1,750 lumens | 1,750 lumens |
Max Run-time | 55 days | 45 days | 100 days |
Max Light Intensity | 23,000 Candela | 12,300 candela | 14,400 candela |
Waterproof | IPX8 | IPX8 | IPX8 |
Weight(Including Battery) | 6.21 oz | 4.3 oz | 4.3 oz |
Size (in) | 5.47*1.16 | 4.65*0.98*0.91 | 4.37*0.91*0.91 |
Battery Capacity | 5000mAh 3.6V | 3500mAh 3.6V | 3500mAh 3.6V |
Rechargeable | Yes | Yes | Yes |
Warrior 3S High Beam Tactical Flashlight
Output:
Discover unparalleled brightness with the Warrior 3S torch. Equipped with a powerful cool white LED and advanced TIR optical lens, it provides an extraordinary brightness of up to 2,300 lumens. The meticulously engineered lens guarantees optimal dispersion of light and precise beam management, allowing it to reach an astonishing distance of 300 meters. Boasting an impressive maximum runtime of 55 days, this dependable flashlight is ideal for thrill-seekers, nature lovers, and tactical experts. Light up your expedition with unwavering assurance, even in the most demanding circumstances.
Sensor:
The incorporated proximity sensor is specifically engineered to identify objects in close range and dynamically adapt the brightness level accordingly. This cutting-edge feature guarantees not only the required illumination but also prevents any inadvertent damage to the environment. In high, turbo, or strobe modes, the flashlight promptly adjusts the brightness when it detects nearby objects. This enables seamless navigation through confined spaces, close-range operations, or usage in crowded scenarios, all while ensuring the utmost safety by avoiding unintended harm to individuals or fragile objects.
Switch:
Utilizing both a side switch and a dual-stage tail switch, this flashlight offers a smooth transition between regular usage and tactical applications. Engineered for convenience and adaptability, it incorporates a side switch for effortless mode selection during everyday tasks. With 6 distinct modes at your disposal, you can easily customize the lighting to match different scenarios. For tactical operations requiring precise control, the Warrior 3S is equipped with a dual-stage tail switch, enabling quick response and immediate action.
Warrior Mini 2 Compact EDC Tactical Flashligh
Output:
Offering an impressive 1,750 lumens of output and a beam reach of up to 220 meters, this flashlight emits a formidable light that effortlessly penetrates the darkness. Say goodbye to straining your eyes to see what lies ahead; this reliable tool will illuminate your path, guaranteeing safety and clarity in all circumstances. Moreover, this version showcases an exceptional maximum runtime of 45 days. Gone are the times of frequently replacing batteries or anxiously anticipating power depletion during critical situations. With this flashlight at your side, you can embark on extended expeditions or confidently rely on it as an indispensable component of your emergency kit.
Sensor:
Featuring an integrated proximity sensor, this flashlight has the ability to detect nearby objects. In the event of an object coming into close proximity, the flashlight will automatically adjust its brightness level to prevent excessive illumination intensity on the object or person. This intelligent functionality not only prioritizes user and bystander safety but also protects the surrounding environment by minimizing unwanted glare.
Switch:
Uncover the remarkable adaptability of this flashlight through its dual switch system. Engineered to cater to your requirements in both regular usage and tactical scenarios, it delivers an elevated user experience. The inclusion of a convenient side switch enables effortless toggling between 6 distinct modes for everyday tasks. Furthermore, the presence of a dual-stage tail switch streamlines and amplifies the effectiveness of tactical operations.
Warrior Mini 3 Portable Tactical Flashlight
Output:
No matter if you find yourself in a dense forest or strolling through dimly lit urban streets, the Warrior Mini 3 flashlight excels in providing bright and enduring illumination. Boasting a maximum output of 1750 lumens, it matches the performance level of its predecessor, the Warrior Mini 2. However, it surpasses its predecessor with an upgraded maximum runtime of an astonishing 100 days and an impressive maximum throw distance of 240 meters. These exceptional attributes guarantee not only clear visibility over long distances but also the ability to reveal even the most unnoticeable details hidden within the darkness.
Sensor:
The Warrior Mini 3 incorporates an ingenious proximity sensor, offering not only pocket-friendly operation but also granting users immediate access to full power when in close proximity. Should the light accidentally switch to high mode while obstructed at a short distance, the proactive proximity sensor will automatically reduce the output to prevent any potential risks. However, when faced with objects like raindrops or window glass while utilizing the high mode, the sensor will not impede the desired output. This proactive proximity sensor greatly enhances the flashlight's safety and user experience, particularly in confined spaces or intricate surroundings.
Switch:
The Warrior Mini 3 is equipped with a metal side switch, making it perfect for everyday use by providing quick and easy access to 6 different modes. The metal side switch has been thoughtfully enlarged and fortified with wear-resistant properties, ensuring a smooth and reliable operation that will delight your senses.
Additionally, this portable tactical flashlight features a tactical tail switch that enables efficient operation during critical situations. Thanks to the advanced Nano Molding Technology applied to the tail switch, cleaning off any pesky metal dust becomes effortless, guaranteeing optimal performance at all times.
Irrespective of whether you identify as an adventure enthusiast, an outdoor lover, or a tactical expert, the Warrior Mini 3, Warrior Mini 2, and Warrior 3S serve as the ideal companions for your ventures. With their exceptional brightness, extensive runtimes, and advanced sensor technology, these compact tactical flashlights provide an unmatched lighting experience. Illuminate even the most obscure corners, conquer formidable situations, and rely on the dependability of these portable tactical flashlights to navigate your path.
