What is LEP flashlight?
The full name of LEP light is Laser Excited Phosphor. It uses a lens to focus a blue laser onto a phosphor element attached to a metal base, which produces a spotlight beam with a much longer throw distance than LED lights. Due to its strong and pure beam, LEP technology has been widely used in various fields, such as high-altitude search, maritime rescue, and field search. Therefore, it is expected to replace LED light sources and become the leading technology in the near future.
How Does LEP light work?
There are two approaches to generating LEP light. One approach is to create a white laser, while the other involves using blue-emitting LEDs combined with Indium Gallium Nitride (InGaN) and yellow phosphor powder. This process creates a Phosphor-Converted LED that utilizes blue light to excite the phosphor powder, generating a mixture of blue and yellow wavelengths that result in a broad-spectrum white light. Moreover, LEP lights exhibit high emission efficiency and consume less power compared to other light sources. Blue light only necessitates a typical drive current of 4.2 mA to achieve the desired light intensity, whereas red and green lights require 8.8 and 10.5 mA, respectively.
LEP VS LED flashlight
LEP flashlights utilize laser beams to stimulate phosphor materials, creating a remarkably intense and focused beam of light. Conversely, LED flashlights employ an array of diodes to generate light. The primary difference between the two is their beam distance and intensity. LEP flashlights have a significantly longer beam distance and provide a highly concentrated ray of light, rendering them ideal for pursuits like hunting, camping, or outdoor exploration. LED flashlights, while still potent, have a somewhat shorter beam distance and are typically used for regular and everyday lighting purposes. Additionally, due to their innovative technology, LEP flashlights often carry a higher price tag than LED flashlights.
How to choose the best LEP flashlight?
When selecting the best LEP (Laser Excited Phosphor) flashlight, it is important to consider several factors. These include:
Brightness: Determine the required level of brightness for your intended purpose. Check the output in lumens or candela.
Beam Concentration: LEP flashlights have a strong, concentrated beam and a long throw, making them ideal for long-range illumination. Select a flashlight with the desired beam concentration based on your requirements.
Battery Life: Verify the battery life of the flashlight and ensure that it meets your usage needs.
Durability: Opt for LEP flashlights made from durable materials such as aluminum, stainless steel, or titanium, which are more resistant to impacts and scratches than plastic.
Brand and Reputation: Always choose a reputable brand that offers a warranty for peace of mind.
Olight Valkyrie Turbo LEP Tactical Light
The world's first lep weapon light for short setups
We want to say how unique and special this is!
Whether you currently possess multiple weapon lights or are in search of your first, look no further than the revolutionary Valkyrie Turbo! With cutting-edge technology and outstanding performance, nothing compares. This world-first WML (Weapon Mounted Light) is an LEP light, flawlessly configured for handgun mounting, providing you with a clear view of your target regardless of lighting conditions. Its compact size, combined with a remarkable 530-meter beam distance and 70,000+ Candela output, truly sets it apart from the rest! We can't emphasize enough how groundbreaking this technology is! Using an LEP light source to illuminate targets over great distances, the Valkyrie Turbo accomplishes feats that no traditional weapon light can match. We believe all handguns, as well as long guns, deserve one. Especially for those unique pistols, a one-of-a-kind light is a must-have!
✅Much brighter compared to LED lights at the same distance With its tightly focused LEP beam, the Valkyrie Turbo delivers an extremely intense hotspot and minimal spill. Its light intensity reaches 70,225 cd, considerably higher than LED lights of similar output, making it brighter at any range.
✅LEP tight spotlight with a remarkably long throw Instead of using a light-emitting diode, the Valkyrie Turbo utilizes a laser-excited phosphor (LEP) design to illuminate. This design results in an incredibly tight spotlight with a throw of 530 meters, far more than what you'd get with a conventional LED light.
✅Conquer the dark The Valkyrie Turbo takes advantage of LEP's tight spotlight, providing clear illumination of your target for as far as the eye can see.
✅Two rail adapters for your liking Easily and securely attach or detach to both Picatinny 1913 and Glock accessory rails.
✅Quick installation system The locking swing arm allows for swift attachment and detachment.
✅Long battery life Two CR123A batteries power the Valkyrie Turbo, providing a maximum runtime of 184 minutes. No waiting for recharging – just replace the batteries and go!
✅Fast operation Swiftly turn the light on/off and access the strobe feature using its ambidextrous switch, allowing you to operate without breaking your grip.
