Olight i1R 2 Pro Kit Small Keychain Light
$29.95
Color:Black
Overview
● Higher-performance: The CSP LED paired with a TIR optic lens, generates a max output of 180 lumens, 48m, 20% higher than i1R 2.
● New charging type: Adopts the new USB-C port instead of the old Micro-USB port, which makes charging easier. The Built-in 130mAh Lithium-ion battery allows the light to run up to 12 hours.
● Easy to use: With a simple twist of the head, users can turn the light on/off and switch outputs.
