Imagine you are on a call but your smartphone dies! Or you're driving and you're about to reach your destination, but your car breaks down! Or you're working or walking in the dark, but your light source is missing! The first two examples might just be an inconvenience, but the last one might be more of an annoyance.
A dependable light is essential for everyday activities. From long hikes in the woods to maintenance work on the factory floor, adding Olight lights to your gear can boost your productivity and go further on your hikes.
High lumen counts, long runtime, and ease of use are all must-haves when choosing an outdoor headlight. We highly recommend checking out the Olight Perun 2. Great features that make the Olight Perun 2 Headlamp ideal for jogging, camping or for adventure and emergencies include:
· Maximum output 2500 lumens
· Up to 12.5 days of runtime
· Versatility: Headlight with headband and two-way pocket clip as EDC flashlight
· Magnetic end caps: work hands-free
· Vertical lighting
· Built-in distance sensor
· Incredible MCC3 charging cable, charging current up to 2A
· IPX8 waterproof
Night companion
If you're an avid hunter, you're probably going deep into the forest in the dark.
The Olight Perun 2 emits up to 2500 lumens of light - enough to light up an entire area - up to 166 meters, giving you a clear view of your surroundings.
This rechargeable LED headlight is powered by a 4000mAh 21700 battery for up to 12.5 days. In addition to its impressive performance, the Perun 2 can be charged at up to 2A using the practical MCC3 cable. Brightness can be adjusted as desired from 5 to 2500 lumens - perfect for close and far viewing. It also has an SOS function for extra protection on your travels.
From the workplace to camping, the Perun 2 rechargeable headlight is a good helper.
One of the rules of the great outdoors is to always be ready. Sometimes it can be a challenge to find the right balance between too much gear (because you want to be ready for every situation) and the best gear (to get the best weight). The bright light and durable construction of the Perun 2 are also great for your workplace or campsite, making them a safe choice.
Thanks to the ultra-thin optics, the Perun 2 emits a soft, balanced beam. The powerful Olight Perun 2 Rechargeable LED Torch is water and dust resistant and can be used up to 166 meters away. As a result, it can project up to 2500 lumens of light over an impressive distance.
Even a job you love can become frustrating due to inefficient lighting. If you regularly experience shadows and poor lighting on your construction site, it may be time for a change.
The Perun 2 includes a head strap so the flashlight can also be used as a headlight. Also includes a two-way pocket clip for everyday use. You can easily attach Perun 2 to backpack, belt. The Perun 2 also keeps your hands free thanks to the magnetic end caps, making it a great light source. Extremely portable, bright and durable, the Perun 2 packs an incredible punch into a compact design that measures just 120.7mm long and weighs 161g.
The best headlights for trail runners
What makes the Olight Perun 2 headlamp ideal for trail runners?
No matter what terrain or light conditions you're used to, or what time of day you want to run, the Perun 2 will help you run further. Some of the special features that make our headlights ideal for trail runners include:
· Multiple lighting modes to meet changing lighting needs.
· wide range
· Perfect fit headband
· Durable design
· IPX8 waterproof
Running in low light conditions presents unique challenges and benefits, and headlights can help you overcome those challenges and reap the benefits. The Olight Perun 2 is designed to help you maintain a safe and relaxed pace on the track.
While every job requires a different type of light, you can never go wrong with headlights. Because it not only makes your work easier, but also safer because your hands are free. The rechargeable LED flashlight and headlamp Olight Perun 2 is compact, portable and offers different lighting modes. Whether you're looking for a flashlight with multiple functions and modes, or a powerful headlamp, you'll find it in Olight's portfolio of rechargeable LED flashlights.
From May 22th to May 26th, Perun 2 is on sale with up to 30% off.
VIP pre-sale: 5/22 (Monday) 20:00-5/24 (Wednesday) 20:00
For all users: 5/24 (Wednesday) 20:00-5/26 (Friday) 23:59
Buy it here:Olight Perun 2 Best Headlamp
