The Olight Marauder Mini is a miniature edition of the Olight Marauder series of flashlights. It is a strong rechargeable dual beam LED flashlight that provides both throw and flood. The big round LED has been included in the center, providing a 600-meter spotlight beam. Three RGB color LEDs are uniformly distributed around the converging lens, making it perfect for use on any occasion. The toggle switch in the center of the body permits fast access to pick either flood light or spotlight, while the upper rotary knob is intuitive to adjust brightness levels. The flashlight features a thermal sensor that mechanically downshifts light to get a body temperature below fifty degrees when there is continued high output use.
Searchlight Power, Mini Size
Get all the energy of a searchlight in this little model, the Marauder Mini. You would not miss a beat up to 7000 lumens and six-hundred meters of throw. Light up the night with a floodlight to scour big areas or a spotlight to hone in on details. This kind of power packed into a compact device makes it best for fishing, camping, search, emergency preparedness, and rescue.
Four Light Colors, More Options
Now with green, red, and blue light modes, you can perform more with your searchlight. Red light is perfect for signaling in emergency conditions, while green light can help you preserve your night vision if out on a rescue or hunting mission. Blue light highlights animal eyes or fish underwater, providing you the capability to see more and stay safe.
Perfect Design and Other Features
Toggle between settings with ease thanks to the torch rotary switch. The LED at the center points out what color light you have it set to. Switching between light colors is as simple as holding down the key switch for one second. To increase brightness, just turn the wheel!
And, in a pinch, you can still switch between spotlight and floodlight thanks to the toggle switch. With the flick of a switch, you can access the setting you need most. Olight's straightforward design makes it simple to access a lot of settings in any state of mind, so you can use your light without any issues when you need it most!
The Advantages of Using Marauder Mini Rechargeable LED Flashlight
The Marauder mini is a miniature edition of the Light Marauder flashlights series.
It is a strong rechargeable dual beam LED flashlight with both flood light and spot light.
The Marauder mini is the best flashlight for those who need a strong and bright light, but don’t want to hesitate a bulky and big flashlight with them.
It features a thermal sensor that mechanically downshifts the light to get a body temperature below fifty degrees when there is a continuous output use.
It is also remarkable for camping trips or other outdoor activities where you need a durable and reliable flashlight.
A big round LED in the center for a strong 600-meter spotlight beam
An intuitive toggle switch that lets you immediately switch between floodlight and spotlight mode.
Three RGB color LED that can be used for any event
FAQs
What Are the Upgrades Matched to Marauder 2?
⚫ RGB lights and a light color indicator
⚫ Bottom magnetic charging
⚫ Vibrating charge indication
⚫ Spot beam shape replaced from square to circular
What Are the Differences between Marauder Mini and Marauder 2 in Shape?
The head diameter is reduced by sixty percent, and the diameter of the barrel is reduced by twenty percent. The reduction in barrel size provides it with a more relaxed and safe grip.
How Long Does It Take to Charge?
It takes approximately five hours to be completely charged by MCC3 magnetic charging cable.
How to Switch between RGB Light and White Light?
The default white light is turned on, press and grip the button for one second to switch to the red light. Press again for one second to switch to the green light. And then press again for one second to switch to blue light.
For Consumers
The Olight marauder mini is a remarkable flashlight for those who want a simple to use, safe flashlight, with either long runtimes or very high brightness at lower brightness levels. The highest brightness of 7000 lumen on L7 is enough for 99 percent of flashlight requirements. Ten hours of 400 lumen runtime on L3 makes this great light for camping, night hikes, search and rescue or for people with big properties. The capability to switch between flood and throw is extremely helpful, as are the RGB options.
For night photographers/painting – the Olight Marauder mini is the best option for when you need lots of floody sustained lumens without the light dimming immediately like most other flashlights. For backlighting, it is up to x10 brighter than a Lume cube. The throw beam permits for more controlled illumination of distant objects.
Overall, the Olight Marauder is highly advised, and in my point of view one of Olight's most attractive flashlights. It is no shock that initial sales figures have been extremely high. The Marauder mini concept has a lot of potential in the future if Olight also considers other configurations such as cool/white switching.
User Review
Great everyday light with lots of lower light output settings for close-in use. Further to the maximum lumen mode. Max lumen mode is very remarkable. Great finish, fit, and balance, feels good
End Words
The Marauder mini is a strong rechargeable dual beam LED flashlight that provides users with a range of features to pick from. The big round LED in the center and 3 RGB color LEDs around it make it best for any occasion, while the toggle switch in the center of the body permits fast access to pick either flood light or spotlight. Further, the upper rotary knob is intuitive to adjust brightness levels.
