As one of the best portable flashlights of 2023, the Olight Baton 3 Pro stands out for its brighter, longer-lasting light, making it a powerful tool for outdoor activities and long work days.
Brighter and longer lasting
Olight Baton 3 Pro has a maximum output brightness of 1500 lumens and a maximum illumination distance of 175 meters. Whether it's outdoor adventures or night work, this flashlight provides powerful and clear light to help you accomplish a variety of tasks.
Plus, the Olight Baton 3 Pro has a battery life of up to 120 days, so you won't need to recharge or replace batteries frequently. The long battery life makes it ideal for professionals who work long hours.
Unique and convenient design
The Olight Baton 3 Pro features a new body relief design for a more comfortable grip and increased slip resistance. Whether you're using it in wet conditions or wearing gloves, this flashlight provides a secure grip for safety and ease of use.
The side button on the flashlight has also been redesigned to be larger and more raised. This innovative design not only makes operation easier, but also reduces the chance of accidental activation. This ensures that the battery will not be drained by mishandling when not in use.
In addition, the Olight Baton 3 Pro is also equipped with a widened and extended two-way clip, which is more securely attached to pockets and backpacks. Whether you need to attach the flashlight to your belt, pocket, or outdoor gear, it provides a secure hold for easy portability and use.
Two color temperatures are available
The Olight Baton 3 Pro is available in two color temperature options: Cool White and Neutral White. Cool white light is suitable for scenes that require high brightness, such as outdoor exploration, search and rescue, etc. Neutral white light is softer and suitable for everyday lighting, reading and indoor use. According to personal needs and scene requirements, choose a more suitable color temperature to provide the best lighting effect.
Fast charging for easy storage
Olight Baton 3 Pro is equipped with an MCC3 USB magnetic charging cable, which can be fully charged in just 3.5 hours. The fast charging feature allows you to provide reliable power to the flashlight at any time without waiting for a long time.
In addition, the product comes with an L-shaped bracket, which can be easily fixed anywhere. You can stick the L-shaped stand on the wall, tabletop or other flat surface, which is convenient for you to store the flashlight after use. This design ensures that the flashlight is stored securely from loss or damage and easily accessible at any time.
Summarize
Olight Baton 3 Pro is an upgraded version of S2R Baton II. With a more powerful maximum output brightness of 1500 lumens and a maximum illumination distance of 175 meters, it is 30% higher than S2R Baton II. Two color temperature options, cool white and neutral white, meet various needs and adapt to different scenarios. The redesigned embossed design and larger recessed side buttons make it more comfortable and easy to operate. Equipped with a customized 3200mAh rechargeable lithium-ion battery, it can be fully charged in just 3.5 hours using a USB magnetic charging cable. Olight Baton 3 Pro can run for up to 120 days, and the long battery life is suitable for long-term work. The included L-shaped stand is convenient for you to store the flashlight after use. The widened and lengthened two-way clip is more secure when clipping to pockets and backpacks. The new body embossed design provides better anti-slip and comfortable grip. Olight Baton 3 Pro is fully upgraded and will bring you a better portable flashlight experience.
Choose Olight Baton 3 Pro, enjoy an excellent lighting experience, and let the light go with you!
