For people who love outdoor activities, hikers and campers, flashlights are an essential tool. However, flashlights are not only limited to outdoor activities. They can also be very helpful in indoor activities, such as police investigations and search and rescue missions. Olight has recently released two multi-function flashlights - the Seeker 4 Mini and Arkfeld UV. Both of these flashlights have rare UV functions, and we will compare their key features in this article.
Design:
The Seeker 4 Mini and Arkfeld UV flashlights have unique designs that set them apart from each other. The Seeker 4 Mini is a cylindrical flashlight with a textured handle, measuring 3.43 inches in length and weighing 3.95 ounces. It comes with a convenient side switch that makes it easy to use. Meanwhile, the Arkfeld UV flashlight has a flat design with a non-slip handle, making it comfortable to hold. It measures 4.33 inches in length and weighs 3.07 ounces. It can easily fit into your pocket for easy carrying.
Lumens, Beam Distance And UV:
The brightness of a flashlight is crucial for various activities. Two important aspects to consider are lumens and beam distance. The Seeker 4 Mini flashlight offers a maximum output of 1200 lumens and a beam distance of 120 meters, which is ideal for outdoor activities. It also has a low-light mode at 2 lumens, perfect for reading or other activities that require less light. Additionally, the Seeker 4 Mini features a UV light with 760mW electric power. The Arkfeld UV flashlight, on the other hand, boasts a maximum output of 1000 lumens and a beam distance of 85 meters, which provides ample brightness. It also features a UV light with 580mW of electric power.
Battery:
Power is very important for both the Seeker 4 Mini and the Arkfeld UV flashlights, and both are rechargeable. However, the two flashlights have different batteries. The Seeker 4 Mini is featured with a removable 1100mAh rechargeable lithium-ion battery, which can be replaced easily. It provides up to 12 days of run time at 2 lumens on the lowest setting and recharges quickly in just 1.5 hours using the included magnetic charging cable. Meanwhile, the Arkfeld UV flashlight uses a non-removable battery that is built-in. It has a 1050mAh lithium-polymer battery that can provide up to 8 days of runtime on the lowest 1 lumen setting.
Function:
The Seeker 4 Mini and Arkfeld UV flashlights are designed with different functions that cater to different needs. The Seeker 4 Mini, for instance, uses a detachable battery system that allows you to bring an extra battery when going on extended outdoor activities. Moreover, it comes with a Metal Side Switch design that makes it easy to use. Conversely, the Arkfeld UV features a Central Button Plus Selector that enables you to rotate between LED and UV modes effortlessly. Both flashlights have battery indicators, which help users monitor the battery life and avoid running out of power unexpectedly. These features make the Seeker 4 Mini and Arkfeld UV flashlights reliable tools for various applications.
Conclusion:
In conclusion, both the Arkfeld UV and Seeker 4 Mini flashlights are exceptional products with unique strengths. The Seeker 4 Mini has a shorter body compared to the Arkfeld UV, a more powerful UV lamp, and a brighter maximum output and light distance, making it a better fit for outdoor settings. On the other hand, the flat design of the Arkfeld UV makes it easier to carry, and its sleek design makes it an excellent choice for business use. Each flashlight boasts unique features that cater to specific needs, ensuring they are both reliable tools for various applications.
