Have you ever wondered what you'd do in a power outage that lasts for days? Or how you'd find your way in the dark during a camping trip gone wrong? Lighting is a crucial component of your survival gear. This guide will find out the importance of lighting in emergency preparedness and what types of lighting we strongly recommend.
Why Does Lighting Matter in Your Emergency Kit?
Picture this: you're deep in the woods, the sun has set, and darkness descends quickly. Suddenly, a storm rolls in, and you find yourself in need of shelter. What do you reach for first? Your lighting gear, of course!
Lighting ensures you can see and be seen when it matters most. Also, it is essential for attracting emergency attention. This could make all the difference in getting rescued swiftly in remote areas.
Choosing the Right Lighting Gear
Here are three types of lighting that could be lifesavers in a survival scenario or medical emergency: flashlights, headlamps, and lanterns.
Flashlights
Opt for durable, waterproof models with long battery life. EDC flashlights are lightweight and energy-efficient, perfect for extended survival scenarios.
1. Arkfeld Pro
The Arkfeld PRO is a portable EDC flashlight that offers three different light sources: white light, green laser, and UV. Its high-performance LED can reach a maximum brightness of 1300 lumens. The inclusion of a 520nm green laser module and a UV light has expanded its range of applications significantly. The circular selector allows users to toggle between them with a simple flick. Monitoring battery usage is made easy with the intuitive battery indicator. Additionally, the flashlight's tail is equipped with a magnetic charging module that supports MCC charging.
2. Seeker 4 Pro
The Seeker 4 Pro features a max output of 4,600 lumens and a 260-meter beam distance. It also includes a 5,000mAh 21700 battery. It features an enlarged metal side switch for improved grip and smoother step-less dimming. This flashlight comes with an innovative holster that offers flashlight auto lock/unlock, charging, storage, and carrying options. It provides dual charging options: Type-C charging (with the holster) and MCC3 magnetic charging (2A charging). You can also select between two different color temperatures, cool white (5700K~7000K) or neutral white (4000K~5000K).
3. Baton 4
The Baton 4 is an upgraded version of the Baton 3. It features a high-performance LED and TIR lens, delivering an impressive maximum output of 1,300 lumens and a beam distance of 170 meters. The Baton 4 features laser micro-perforated indicators that show the remaining brightness and battery life. The custom-designed charging case has a built-in 5000mAh 21700 battery, providing up to 190 days of runtime for Baton 4.
4. Prowess
The Prowess offers forward and reverse lights, which can be easily switched with a flick of the toggle switch. With six high-performance LEDs, the Prowess's front light delivers an impressive maximum output of 5,000 lumens, illuminating up to 245 meters. The reverse light provides a cozy ambiance with stepless dimming and a maximum output of 800 lumens. Powered by a 5000mAh lithium-ion battery, the Prowess ensures up to 20 days of continuous Moonlight. It also supports USB-C charging via the detachable base and MCC charging with an optional MCC3 cable.
Headlamps
Hands-free lighting is invaluable during tasks like setting up camp or navigating trails after dark. Look for adjustable brightness settings and comfortable headbands.
1. Perun 2
With a max 2,500-lumen output, the Perun 2 can be used as both a right-angle headlamp and as a powerful EDC. It also reduces the brightness and power off within 1 minute to prevent overheating when detecting an obstruction nearby. Magnetic base for attaching onto the iron surface, stainless steel pocket clip, and adjustable headband with silicon switch for leaving both hands to work. Are you still troubled by hands-on situations when walking your dog or camping with your friends? The Perun 2 will be your best helper with huge performance, multiple applications, and robust design.
2. Perun 2 Mini
Perun 2 Mini is as small as your thumb but boasts a max output of 1,100 lumens, providing quality light while not impairing your night vision and perfect for use as an emergency warning signal at night. It can be used as a Handheld EDC flashlight, or as a headlamp with the upgraded headband! It can even magnetically attach to any iron surface to be used as a work light. Perun 2 Mini has three colors that accurately indicate the remaining power. (Green:>60%, Orange:60%~10%,Red:10%~5%, Flashing Red:<5%) The contact area between the headband and the skin has been reduced, making it more comfortable and lighter to wear. It is equipped with a USB magnetic charging cable for an easy and fast charging experience.
Lanterns
Propane or battery-powered lanterns provide excellent ambient lighting for base camps or group settings. Some models even offer USB charging capabilities for versatility.
Olantern Stretch is a creative and versatile addition to the Olantern Series, the industry's 1st lantern that features a height-adjustable light head for a customizable lighting range. It has up to 500 lumens of white light and 130 lumens of warm light. Suitable for any road trip, home party, bed lighting, etc. Its battery capacity is 16000mAh, up to 250 hours of lighting time. Switch between two light sources with a flick by using the toggle switch.
When it comes to lighting in emergency preparedness, it's better to be over-prepared than under-equipped. Invest in quality survival gear that meets the demands of your adventures. Stay safe, stay illuminated, and keep exploring with Olight!
