Are you looking for a powerful flashlight, but don’t want to burn a hole in your wallet? If yes, we hear you.👂
When you have purchased and reviewed so many tactical flashlights, you realize that these are more expensive than any other type of flashlight. Tactical flashlights are a little different than regular flashlights. Their unique features, functionality, manufacturing process, and overall body construction are what makes them expensive. Only a few flashlight manufacturing companies give you premium quality tactical flashlights under 💰$100, and Olight is one of them.
Why is Tactical Flashlight Expensive?
Unlike normal EDC flashlights, tactical flashlights are made for special situations. As the saying goes, anything that is made for special situations has special features; this applies to tactical flashlights too. Tactical flashlights are more expensive than other flashlights because they are designed to be more durable and feature-rich. They are made of higher-quality materials and have advanced features such as rugged body construction, strobe mode, multiple brightness levels, proximity sensor, tail switch, and more.
Though tactical flashlights are often used by the military and law enforcement, you as a civilian can also buy one for yourself. You can use this flashlight for self-defense, outdoor activities, illuminating dark areas, and sending signals in demanding environments when required.
One standout feature of a tactical flashlight is that it can be mounted on a firearm or used in conjunction with other tactical equipment, such as helmet mounts. On the expensive side, some even come with a built-in laser beam.
In general, tactical flashlights are more specialized and are intended for use in specific situations where a more robust and feature-rich flashlight is needed. This is what makes them more expensive than other flashlights.
Three Olight’s Tactical Flashlights You Can Buy
In today’s oversaturated market, It is really hard to find a quality tactical flashlight under $100. Less expensive tactical flashlights are either too bulky, made of plastic, or lack enough lumen output. For years, Olight has spared no effort in creating high-quality and reliable illumination tools, which enable Olight to have the best partners and fans worldwide. The best thing is that Olight will launch new products and flash sales every month. Products that are on the expensive side often have 30% off and sometimes even more.
🔥🔥🔥Warrior Mini 2 Compact EDC Tactical Flashlight
The Warrior Mini 2 is one of the most budget-friendly powerful compact tactical flashlights on the market today. It is an upgraded version of the previous warrior mini. It produces an astounding max output of 1,750 lumens and a 220-meter beam distance despite its pocketable size. Its newly adopted proximity sensor drops the brightness level proactively in case of obstruction. As the successor of Warrior Mini, this flashlight still features a side switch for daily use and a tail switch for tactical operation. The three-level battery indicator tells the battery level and when to charge, and the customized 3500mAh 18650 battery charges with the MCC3 magnetic charging cable. In addition, the included carabiner-style ring (not for climbing) is added for enhanced portability. Compared to its predecessor, the Warrior Mini 2 is more secure, way brighter, and packed with new refinements that make it one of the most well-designed tactical pocket lights out there.
🔥🔥🔥Warrior 3S High Beam Tactical Flashlight
Normally, the Warrior 3S flashlight is an expensive tactical flashlight with an MSRP above $100.Clearly over the $100 budget, but you can get it for $90 or less during the Olight flash sale. By the way, you'll also get a free flashlight gift during the Olight flash sale!
So, how is Warrior 3S superior to other tactical flashlights?
Olight lovers can immediately tell the difference between Warrior 3S and other warrior series flashlights by just looking at it. For those who’re new to the Olight, let me explain it to you.
Warrior 3S is one of the best tactical flashlights above 2000 lumens in the Olight warrior series. It’s cool white LED, paired with the TIR optic lens can deliver up to 2300 lumens, 300-meter beam distance, and 55 days runtime.
You get two operating modes, a side switch, and a tail switch. You can use the side switch for normal on/off and the tail switch to activate direct turbo or strobe mode with a single press.
It also has a 4-level battery and brightness indicators that give your real-time status about your battery and brightness level at a glance. A Built-in proximity sensor prevents the flashlight from overheating.
Warrior 3S will satisfy your tactical needs in various situations such as hiking, camping, self-defense, and law enforcement.
🔥🔥🔥Warrior X 3 2500 Lumen Tactical Flashlight
The Warrior X 3 is an upgraded version of the Warrior X Pro and is packed with great tactical features. Its max output is increased by 400 lumens to 2,500 lumens and its max beam distance reaches 560 meters. Like its predecessor, it has a dual-stage tactical tail switch to access high/low output either momentarily or constantly. The tail switch accepts an optional lockable, dual-button magnetic remote switch and supports Olight’s signature magnetic charging. Powered by a customized 5000mAh 21700 Li-ion battery, it can be recharged via the MCC3 charging cable and runs up to 8 hours. The Warrior X 3 has been upgraded with 3 zirconium beads embedded in the strike bezel which help break glass in an emergency. The included Warrior Ring and silicone tactical grip ring provide better control of the flashlight during stressful moments. When the power is low, the internal motor silently vibrates to remind you to charge the battery. The rugged aerospace-grade aluminum alloy body has a non-slip knurled grip and features an IPX8 waterproof rating and 2-meter drop resistance. With all-around tactical features, the Warrior X 3 delivers expert-level tactical performance.
A tactical Flashlight is a Useful Device to Carry Around
Investing in a tactical flashlight can be one of the best investments you can make in everyday security. Most people think buying a flashlight is a waste of money, but they’ll never know its importance unless they own one and use it. Stop relying on smartphone lights!
The three most important features you should look for in a tactical flashlight are Lumen, light mode, and material. The Olight warrior series flashlights have a lumen output of 1000 and above, they have multiple brightness levels including strobe and the body is made of aluminum alloy.
More than the features of a flashlight, what is more, important is the brand. Just think for a second, why do people buy an iPhone when it’s the most expensive smartphone? Apple is a brand and its products have top-notch quality and features.Similarly, when you buy a flashlight, look for reputable brands. When you buy from brands such as Olight, the price you pay is always worth the price.
