For outdoor enthusiasts, a flashlight isn’t just an accessory; it’s a trusted companion that can turn uncertainty into confidence. Olight’s original Marauder Mini won hearts for its compact power, but the Marauder Mini 2 redefines what a portable flashlight can do. This upgrade fixes every pain point of its predecessor while cranking up performance, versatility, and convenience.Let’s dive into why it’s time to trade up.
The 5 Key Upgrades That Outshine the Original Marauder Mini
The first Marauder Mini was a solid choice, but the Mini 2 transforms “good” into “essential” with upgrades tailored to Canadian needs. Here’s how it outperforms the original in ways that matter most:
1. Compact Size + Monster Performance: 10,000 Lumens + 750m Throw
Despite the power boost, it stays compact: 465 grams and a slim profile that fits in your backpack side pocket or glove box. The balanced design lets you hold it one-handed for hours---perfect for early morning dog walks/strolls or setting up a camping tent in the rain. And with a 7500mAh battery, it offers up to 5 months of runtime on low brightness, so you won’t be caught without light on extended trips or emergency kits.
2. 5 Independent Lighting Modes: Perfect for Every Scenario
The Marauder Mini 2 adds three game-changing options to cover every situation:
Spotlight: Delivers a concentrated, long-range beam (up to 750 meters) engineered for precise targeting. Ideal for scanning distant terrain, identifying far-off objects, or signaling for help in low-visibility conditions—no squinting or straining to make out details, even at maximum range.
Floodlight: Emits a wide, 10,000-lumen beam that covers large areas evenly. Designed to eliminate dark spots, it’s perfect for illuminating entire campgrounds, work zones (like vehicle engine bays or gear setups), or large outdoor spaces where full visibility is needed without constant light adjustment.
Spot + Flood Combo: Syncs the focused spotlight with the wide-reaching floodlight in a single tap. The spotlight locks onto your target (e.g., trail markers, wildlife, or obstacles) while the floodlight brightens your immediate surroundings—letting you navigate safely while keeping an eye on distant details.
Side Light: Features a soft, diffused LED on the flashlight barrel that emits gentle, non-glaring illumination. Perfect for close-up tasks: reading maps, rummaging through backpacks, prepping meals at camp, or using inside tents without blinding yourself or fellow adventurers.
Red Light: Operates on a low-intensity wavelength that preserves night vision—critical for after-dark activities. Unlike white light, it won’t cause temporary blindness when switched off, and it’s far less likely to disturb wildlife or other outdoor enthusiasts. Use it for late-night navigation, stargazing, or early-morning outings to stay aware of your surroundings without disrupting natural environments.
This versatility means you’ll never need multiple lights again—one tool handles everything from backcountry adventures to backyard camping.
3. One-Button Dual Dial Control: Easy to Use with Gloves On
The Marauder mini 2 features an intuitive triple-control system—rotary selector, toggle switch, and rotary knob—enabling quick and
seamless switching between light modes and brightness levels.
Even with frozen fingers in the cold winter, it's easy to operate. Simply rotate the knob to dim the floodlight; or toggle the lever to easily switch between spotlight and red light modes—no more memorizing tedious click operations. For Canadians who brave sub-zero temperatures, this upgrade turns “hassle” into “seamless control.”
4. Dual Charging: MCC Magnetic + USB-C for Off-Grid Flexibility
The Marauder Mini 2 adds USB-C charging to the mix, so you can top it up with a standard phone cable, power bank, or solar charger—critical for backcountry trips in Canada’s remote regions.
5. 2-in-1 Lanyard-Charging Cable + Improved Grip
The Marauder Mini 2 upgrades standard lanyard to a detachable USB-C charging cable. The integrated lanyard doubles as the charging cable, eliminating the hassle of forgetting your cable. Simply remove it when you need to charge—no more stuffing your bag with extra charging cables, and no more frantic searching when you realize you've forgotten yours outdoors.
The Marauder Mini 2 also gets an upgraded grip: the ergonomic design and faux leather texture provide superior traction compared to the original’s smooth surface. Whether your palms are sweaty after a climb or you're wearing gloves while snowshoeing in winter, it won't slip out of your hand. While the original might have felt bulky in wet or snowy conditions, this improvement makes the Mini 2 more reliable in Canada's variable climate.
The Marauder Mini 2’s compact size, powerful performance, and versatile features make it a top pick for Canadian outdoor enthusiasts, car owners, engineers, law enforcement officers, and professionals from all walks of life.
This Black Friday, Olight is offering an amazing deal: 20% off the new Marauder Mini 2 for a limited time. Whether you're looking to upgrade from your original Marauder Mini, replace an old flashlight, or add an essential tool to your outdoor gear, don't miss this rare discount.
From November 12th to December 1st, special sale with up to 20% off.
⏰VIP pre-sale: 11/12 (Wednesday) 8:00 PM-11/14 (Friday) 8:00 PM⏰
⏰For all users: 11/14 (Friday) 8:00 PM-12/1 (Monday) 11:59 PM⏰
Shop the Marauder Mini 2 now, up to 20% off
