Two years ago, Arkfeld changed the way people thought about flashlights. With its slim, flat design and multi-light functionality, it broke away from the limits of the traditional cylindrical form—and went on to become a phenomenon. Loved by nearly one million users and topping Amazon's charts week after week, Arkfeld proved that innovation and everyday carry could go hand in hand.
Today, that legacy evolves into something even bigger: the ArkPro Series. With smarter multi-light versatility, intuitive design, and premium craftsmanship, ArkPro isn't just a tool—it’s a companion that redefines what a flashlight can be.
ArkPro – Rethink Light. Reimagine Style.
Rethink Light "3 + 1 = 7"
At the core of ArkPro is the principle of “3 + 1 = 7” Three light sources—Flood, Spot, and UV—plus a green laser, which can work independently or in combination. This gives you seven distinct modes in a single flashlight, simplifying your gear and unlocking real versatility.
Pure Flood – Smooth, Wide, Comfortable
Traditional flashlights often create a blinding hotspot in the center and uneven edges—fine for quick bursts, but tiring for close-range use.
ArkPro's Pure Flood is different. It delivers a beam that's soft, even, and natural—like daylight through a window or moonlight outdoors. Instead of glare, you get clear, balanced light that feels comfortable to work under.
Whether fixing circuits during a blackout, cooking at a campsite, or taking a nighttime walk, Pure Flood lights your surroundings naturally. And with 1,500 lumens (15% brighter than Arkfeld Pro), it’s not just brighter—it’s smarter illumination made for real life.
Spot Beam – Precision at a Distance
A focused 800-lumen beam that reaches up to 205 meters—ideal for outdoor patrols, night hikes, or checking distant details around your property.
UV Light – Hidden Details Revealed
A two-level UV mode (1200mW / 360mW) lets you authenticate currency and IDs, detect stains or car fluid leaks, and explore natural fluorescence.
Green Laser – Point, Guide, Combine
Stronger than ever (Class 3R ≤5mW, Class 1 ≤0.39mW), the green laser is controlled via a dedicated side switch. It works alone or alongside any beam—Flood + Laser, Spot + Laser, UV + Laser—for seamless guidance and precision.
Reimagine Style – Design Meets Refinement
The Industry's First Dual-Tone Flashlight
A bold dual-tone finish, like day and night in balance, elevates style and makes ArkPro stand out as the first of its kind.
Edge in Design. Flat to Carry.
With its slim 16mm profile and central ridge for structure, ArkPro slips effortlessly into your pocket while keeping a strong visual identity.
Craftsmanship in Every Detail
Laser micro-perforated indicator, a clear lockout symbol, a thumb-friendly button, and a dedicated side laser switch—all signs of Olight's refined craftsmanship and commitment to human-centered design.
Rugged Unibody Construction
Perfection isn't assembled – it's sculpted. Each ArkPro is CNC-machined from a solid block of aluminum. With fewer parts and joints, the unibody construction achieves exceptional structural strength and a smooth, sturdy feel in your hand.
Battery & Charging – Power That Lasts
ArkPro is powered by a 2000mAh battery—a 33% increase over previous models—delivering up to 14 days of runtime (Moonlight mode). With USB-C and MCC magnetic dual charging, you have the freedom to recharge anywhere, anytime.
ArkPro Ultra – The Flagship Standard
The ArkPro Ultra is more than just the most powerful member of the series—it's the flagship standard that blends performance, durability, and emotional design into one.
EIP LED – Pure and Powerful
At the core of Ultra is Olight's self-developed EIP LED, delivering a cleaner, purer beam with a maximum of 1,700 lumens. Whether flood or spot, the light feels sharp yet natural, offering professional-grade clarity for demanding tasks.
OAL Body – Strength Meets Style
The Ultra is crafted from exclusive OAL material, giving it a tougher, more premium body. It's a flashlight designed not only to perform under pressure but also to carry the elegance of a flagship product in your hand.
Arkbeat Breathing Light – A Living Pulse
Exclusive to the Ultra, Arkbeat is a breathing light that symbolizes the “heartbeat” of your flashlight. Its color gradually changes with use time—white (2h) → orange (4h) → yellow (8h) → green (16h) → cyan (32h) → blue (64h) → purple (128h)—transforming Ultra from a tool into a companion that quietly reflects your journey.
Shared Features, Turned Up a Notch
Like the ArkPro, Ultra integrates Flood, Spot, UV (two levels), and Laser into seven total modes. But every spec is elevated—Flood at 1,700 lumens, Spot reaching 205 meters, while UV and Green Laser deliver the same trusted performance as ArkPro.
Craftsmanship Refined
Ultra takes refinement a step further with wheat-grain laser micro-perforated indicator—a detail that embodies precision and care. Complemented by sharp geometric lines and subtle laser-engraved icons, the design feels every bit as premium as it performs.
Power That Lasts
A 2000mAh battery and dual USB-C + MCC charging give the Ultra up to 14 days of runtime, ensuring it’s always ready when you are.
Unibody Strength
Each Ultra is CNC-machined from a solid block of aluminum, creating a seamless unibody that combines exceptional structural strength with a smooth, sturdy feel in hand.
ArkPro Lite – The Everyday Essential
The ArkPro Lite is more than just the smallest member of the series—it’s the essential choice for those who want simplicity, portability, and practicality in one compact form.
Three-in-One Light System – Simple, Yet Capable
At its core, Lite integrates three light sources: white light for daily illumination, UV for detection and exploration, and red light for preserving night vision or discreet signaling. Stripped down to the essentials, it’s lean, practical, and ready for everyday use.
Slim Build – Compact Freedom
Lite is the most portable model in the ArkPro family, measuring only 111mm long, 16mm thin, and 105g light. Its flat profile ensures no bulk in the pocket and no awkward carry—just seamless portability whenever you need it.
Design Consistency, Simplified
Lite carries the same DNA as the ArkPro Series, with its flat, refined body, silky selector dial, and thumb-friendly button. It also includes micro-perforated indicators for brightness, battery, and lockout status—keeping operation intuitive while maintaining a clean, stylish look.
Power That Lasts
Despite its smaller size, a 1350mAh battery keeps Lite running for up to 10 days. Dual USB-C + MCC charging ensures flexible recharging at home or on the go.
Unibody Strength
Like its bigger brothers, Lite is CNC-machined from a solid block of aluminum, giving it a seamless unibody construction that balances light weight with durability.
🎁 ArkPro Series Blog Giveaway
To celebrate the launch of the ArkPro Series, we’re giving away 5 prizes, including ArkPro flashlights and exclusive Olight gear—with a total value of over $200!
How to Enter:
1. Scroll down to the comments section.
2. Answer this question: “From Flood to Spot, UV to Laser—share a real-life (or fun!) scenario where you'd put these modes to work.”
We'll randomly select 5 winners from all valid comments, and the results will be announced right here on this blog and via email.
(We will add the prizes to your shopping cart before the ArkPro series goes on sale. Please pay attention to the announcement of the winners on our blog.)
👉 Don't miss your chance—join the conversation below for a shot to win!
Final Thoughts – Rethink Light. Reimagine Style.
The ArkPro Series isn't just a step forward—it’s a complete rethinking of what an everyday flashlight can be. From the smooth, natural glow of Pure Flood, to the reach of Spot, to the hidden insights of UV, and the precision of Laser, ArkPro redefines light itself. And with its slim, flat build, refined design, and intuitive controls, it transforms from a simple tool into a smarter everyday companion.
Ready to experience the future of EDC lighting?
