For outdoor explorers, precision hunting enthusiasts, and rural property owners across Canada, changing seasons bring shorter days and extended hours of darkness, making professional long-throw outdoor lighting and night-time property monitoring essential. To complement your outdoor gear collection, we are proud to introduce the fresh and highly-anticipated Tan color variation of the PL X GL. Whether you are tracking targets during chilly weather or securing a remote perimeter, reliable visibility makes all the difference. To conquer the dark with absolute precision in a striking new finish, look no further than the newly released Olight PL X GL in Matte Black.
- 01. Ultimate Versatility: 1,200-Lumen Floodlight, 260m Spotlight & Green Laser
- 02. Engineered for Durability: Ultra-Rugged 10,000 Rounds Tested
- 03. Hassle-Free Universal Rail Integration and Smooth Fit
- 04. Smart USB-C Recharging and Long-Throw Performance
- 05. Elevate Your Outdoor Setup with Olight PL X GL
- 06. Frequently Asked Questions (FAQ)
Every outdoor or tracking scenario is unique, demanding dynamic adaptation. As an advanced rail-mounted light, the PL X GL integrates a massive 1,200-lumen floodlight for wide-area awareness, a high-intensity 260-meter throw spotlight for distant illumination, and a precise Class 3R green laser. Operators can operate the green beam sight independently or combine it with either white light beam configuration using the full-metal ambidextrous tail switches and dedicated mode selectors.
Canadian weather and demanding outdoor environments demand gear built to endure. Constructed from high-grade 6061-T6 aluminum, the PL X GL features an IPX7 waterproof rating to handle heavy rain, snow, and moisture effortlessly. Certified with a 1.5-meter drop resistance and tested through 10,000 rounds of intensive usage, this ultra-rugged compact rail light maintains absolute stability under heavy operational impacts. It is a dependable companion built for your most challenging outdoor expeditions.
Upgrading your equipment should not disrupt your existing gear ecosystem. The PL X GL is designed with an adjustable, reversible, and replaceable rail lug system equipped with an anti-loosening ratchet, ensuring a rock-solid, universal rail mount compatible fit on major hardware platforms. Furthermore, its thoughtful design ensures broad compatibility with standard carrying solutions from over 16 leading manufacturers, fitting most standard holsters straight out of the box without custom modifications.
Downtime is a major obstacle to efficient outdoor work. The PL X GL features a built-in 620mAh lithium-polymer battery supporting convenient USB-C direct recharging via standard cables, power banks, or vehicle ports, achieving a full charge in just about 80 minutes. For precise tasks, the precision hunting light configuration provides up to 9 hours of continuous runtime, while the built-in battery level indicator ensures you are always aware of your power status.
Do not let low-light conditions limit your performance in the field. Equip your gear with the versatility, power, and ultra-rugged reliability of the new Matte Black Olight PL X GL. Head over to the official Olight website today to purchase yours and take full control of the night.
Olight PL X GL Multi-Source Rail Light
Key Specs: 1,200lm Floodlight, 260m Spotlight, Class 3R Green Laser.
Shop PL X GL →
