The Olight Perun 3 is our all-round pick for routine maintenance where your site permits a general-use headlamp. Its right-angle body works in the supplied headband or as a small task light on a suitable steel surface. The useful headline figure is up to 25 hours at 120 lumens in Olight’s lab, a better starting point for a shift than its two-minute, 3,000-lumen Turbo peak. If your job requires a hard hat, confirm the exact attachment with the helmet maker and your employer before choosing a lamp.
| Option | Best fit | Main trade-off |
| Olight Perun 3 | Headband use or a fixed work light on a suitable steel surface | More weight than a compact backup; needs its magnetic charging cable |
| Perun 3 with a separately verified helmet mount | Workers whose exact hard hat and mounting setup have been approved | The included headband bracket doesn’t establish hard hat compatibility |
| Olight Oclip Pro | Short tasks when you have a stable clip point or a suitable steel surface | The beam follows the mounting point rather than where you look |
| Olight Perun 3 Mini | A small headlamp for callouts and backup | Much less reserve than the full-size Perun 3 |
What to look for in a work headlamp
Start with the distance to your work. For reading equipment labels at arm’s length, look for a broad beam with a comfortable low or medium setting. A tighter beam helps when you need to see farther down a bay, but it can bounce glare back from polished housings or white cabinets. Try pointing the beam slightly down or lighting the surface from the side. The Canadian Centre for Occupational Health and Safety’s lighting guidance explains how adjustable task lighting and positioning can reduce reflections.
Plan for the setting you can use for hours. Read the output and duration together. Separate the time at the advertised peak from the time after the output drops. For an eight-hour shift, estimate actual lamp-on time and check that the useful setting covers it with a reserve. If you rely on high output for much of the shift, plan for a second light or an approved way to swap or recharge batteries.
Inspect the mount, water rating and controls. Try the switch while wearing your work gloves and see whether you can aim the beam without the unit shifting as you look down. A water or drop rating describes a manufacturer test; it doesn’t establish dust protection if the code leaves that digit unmarked, or approval for a hazardous location. Follow the operating temperature for the exact version, particularly for winter service calls and unheated yards.
Four options for a primary light, a hard hat or a backup
Olight Perun 3: Best all-round right-angle headlamp
The Perun 3 manual from Olight Canada lists a 5,000 mAh battery, an MCC3 magnetic charging cable, an IPX8 water rating and a 1.5 m drop rating for the version it describes. It gives these white-light figures under Olight’s lab conditions:
| Mode | Rated output and time |
| Low | 30 lm for up to 89 h |
| Medium | 120 lm for up to 25 h |
| High | 600 lm for up to 5 h, then about 120 lm for 30 min |
| Turbo | 3,000 lm for about 2 min, then about 810 lm for 3 h and 600 lm for 30 min |
Use Medium as a starting point for close work if it lets you see the detail you need. Use High for a larger area when needed. An all-day job that truly requires 600 lm is a reason to carry backup lighting or use a dedicated area light: the High figure is five hours at its initial level, not an eight-hour shift. Treat the table as a planning reference; temperature, battery condition and the way you switch modes can change what you see on site.
The right-angle body also lets you take the lamp off your head, clip it to a pocket if the beam still points where needed, or use the magnetic base as a fixed light. A fixed beam often helps when changing your head angle would otherwise sweep glare across a colleague’s line of sight. Confirm the surface is magnetic and the attachment is stable; use an alternate mount if the light could fall into a work area.
Perun 3 with a helmet mount: Confirm fit before buying
The original Perun 3 package described in the Canadian manual includes a headband and bracket. Before buying a separate mount, ask for the compatible helmet make and model, manufacturer approval, and confirmation that the attachment does not affect fit or interfere with hearing or face protection. The CCOHS guide to selecting protective headwear covers accessory approval, and its headwear care guide advises against drilling or altering the shell. If you cannot verify a Perun 3 setup, choose a light with an attachment documented for your helmet and confirm that combination with your site.
Olight Oclip Pro: Best clip light for short jobs
The Oclip Pro is convenient when your headlamp sends the beam straight into a reflective surface. Use its spring clip or magnetic mounting point to aim the beam across a workbench. The Canadian manual lists USB-C charging, IPX6 water resistance, and up to 3 hours 30 minutes in 100-lumen white flood mode. That makes it a good second light for small repairs. A fixed clip angle is less useful when you need the beam to move with you.
Olight Perun 3 Mini: Best compact headlamp to keep in a kit
At 54 g with the battery, the standard white/red Perun 3 Mini is easier to carry as a spare or wear for shorter tasks. The manual lists a 650 mAh battery and an IPX8 rating for this version. Check the exact package before you buy: the standard model and editions with a charging case are different purchases. For a long outage or an entire shift away from charging, the full-size Perun 3 is the better starting point.
Choose a setup for the way you work
| Trade or task | How to set up your light |
| Electrical maintenance | At a de-energized cabinet, start at a setting that makes labels legible and aim slightly away from reflective covers. Follow your site’s electrical isolation and PPE procedures. |
| Automotive service | Start with a broad beam under the hood; add a fixed clip light on suitable steel to fill the shadow behind a component. Keep lights and straps clear of moving parts. |
| Plumbing or HVAC | A low or medium setting is often easier on the eyes in a small space with shiny ductwork. Carry a backup and follow site procedures if the space is classified as confined or hazardous. |
| Construction and warehouse work | Confirm helmet attachment first where head protection is required. Use a lower, downward-aimed beam near co-workers and a brighter setting only where the task calls for it. |
For work in a classified or confined location, use only lighting approved for the site and conditions. A consumer lamp’s IP rating doesn’t cover this requirement. A headlamp also doesn’t replace required area lighting or the measures in a confined-space safety procedure.
Keep your headlamp ready for the next shift
Wipe grit off the lens and charging contacts according to the manual. Check the strap and bracket for wear, dry the lamp before charging and use the matching cable. If the lamp lives in a service van, check the manual before using or charging it in temperature extremes. The Canadian Perun 3 manual lists an operating range of 0–40 °C. Charge and check the lamp before a callout, then keep your backup somewhere you can reach without the primary beam.
Work headlamp questions
How many lumens do you need for work?
There’s no universal number. Use the lowest setting that lets you clearly see the task without glare. For close work, start with a controllable low or medium beam; check that the beam lights the whole area you need. For longer sightlines, use a more focused beam or more appropriate area lighting. Compare runtime at whichever setting you actually use.
Can I wear the Perun 3 over any hard hat?
Compatibility depends on the exact helmet, the mount and your employer’s requirements. Get confirmation for that combination, and keep accessory fit and clearance in mind. The supplied headband is for headlamp use; it is not proof of approval for a particular safety helmet.
Which headlamp should you buy?
Choose the Perun 3 if you need a right-angle light that can cover long periods of close work and switch between a headband and a stable work surface. If you’ll wear a hard hat every day, start with the helmet manufacturer’s approved setup. Add the Oclip Pro for independent task lighting or the Perun 3 Mini as a wearable backup. Check Olight Canada’s store for the exact version and charging accessories before ordering. If you’re also buying for hiking or winter recreation, see Olight Canada’s general headlamp guide.
