The Olight Arkfeld series has released a total of three flashlights so far. We will objectively compare and evaluate the three flashlights based on technical parameters. Please continue reading to explore their excellent functions and excellent performance so that you can make a better choice.
Quick List
| Length (mm/ in) | Width | Height | Compatible Batteries | Max. Performance (lumens) | laser | UV | price | |
Arkfeld | 4.33 in (110 mm) | 0.98 in (25 mm) | 0.59 in (15 mm) | Built-in 1050mAh Lithium Polymer Battery | 1,000 lumens | √ | × | CAD$120.95 |
Arkfeld UV | 4.33 in (110 mm) | 0.98 in (25 mm) | 0.59 in (15 mm) | Built-in 1050mAh Lithium Polymer Battery | 1,000 lumens | × | 580mW UV Light | CAD$120.95 |
Arkfeld Pro | 4.72 in (120 mm) | 1.06 in (27 mm) | 0.63 in (16 mm) | Built-in 1500mAh Lithium Polymer Battery | 1,300 lumens | √ | 900mW UV Light | CAD$134.95 |
Comparison:Arkfeld VS Arkfeld UV VS Arkfeld Pro
Arkfeld Pro is a combined version of Arkfeld and Arkfeld UV, because it combines white light, green laser, and UV light, which is why it is larger. Regarding their differences, I have summarized the following 5 points.
1.UV light power upgrade
The Arkfeld Pro version has also upgraded the UV light, equipped with a 900mw UV lamp. The UV output is increased by 55% compared to the 580mw of Arkfeld UV. The following is when I turned on two UV lamps at the same time. You can see the obvious range of the Arkfeld Pro version of UV light. Bigger and brighter.
2. Green laser power upgrade
In addition, Arkfeld pro increases the power of the green laser. The following are photos taken by me turning on Arkfeld and Arkfeld Pro green laser at the same time. You can see the obvious difference. The title of Arkfeld Pro is not for nothing.
3.Battery capacity and maximum lumen value upgrade
It is worth mentioning that Arkfeld Pro has a larger built-in battery than the other two versions, with a capacity of 1500mah, which is 42.9% higher than the other two versions, and the maximum lumen value has also increased by 30%. The maximum lumen value of the Pro version is 1300 lumens, the other two versions are both 1000 lumens. Of course, this is also a sacrifice. If I line them up side by side, you will find that the Pro version is much larger in length, thickness, and height, and it is also heavier. Details Parameters can be found in the quick list.
4. Detail Design
The Arkfeld Pro borrows many features from the Arkfeld UV, such as a double-sided non-slip texture and a two-way pocket clip, features not found on the original Arkfeld version, while retaining the narrow design of the tail.
5. Control dial changes
Let's take a look at this rotary dial. All operations can be controlled by this single-sided switch. By rotating it, you can switch between UV light, white light and green laser. But look at the difference on this rotary dial. , it has only one small bump on the dial compared to the two bumps on the previous Arkfeld and Arkfeld UV products. For those who are used to older products, it may take some time to get used to the new watch face.
6. Activate green laser and white light at the same time
Well, there’s a brand new feature that I really like. If you have green laser mode turned on, just double-click the button on the side to enter white light mode and green laser mode at the same time. You can also cycle through modes here, maybe because the green laser is so bright you might not be able to see it clearly, but you can definitely see it in low light. This is something the original Arkfeld flashlight couldn't do, so I thought it would be cool to be able to activate both green laser and white light modes at the same time.
Summarize
I absolutely love the Olight Arkfeld Pro flashlight, it's one of my favorites. Olight has combined the two previous versions of Arkfeld and UV into the Pro version, which I am very happy with. While it may be slightly larger, if you think about it, it replaces two flashlights, so from that perspective, it's not that big. Additionally, the increased 1500mAh lithium-ion battery capacity lets you enjoy longer use, which is always a plus. I think the Pro version of the Olight Arkfeld is a 3-in-1 product while still maintaining typical Olight qualities, making it almost impossible not to like.
