If you are looking for a reliable LED flashlight, brightness is a factor that you wouldn’t want to ignore. However, not every flashlight is made equal. Branded flashlights normally come with better built quality and higher lumen output, which reflected in the price tag. But is there a good quality flashlight that can meet your budget?
Here are some of the best quality bright flashlights for different budgets.
Flashlights Under CAD$50
Olight i3T 2 EOS Small EDC Flashlight
Price: CAD$26.95~CAD$35.95
● Amazingly Bright for Its Size: Fitting in the palm of your hand, the dual-output flashlight can be initially powered on in low or high mode, depending on your needs.
● Flexible Battery Options: In addition to AAA alkaline battery, it is also compatible with 10440 rechargeable lithium ion battery, which can boost the maximum output to 300 lumens.
● Extended Runtime With Lower Temps: The new generation features an extended battery life, increased by 31%, and maintains a surface temperature less than 45°C even during prolonged use.
● Enhanced Pocket Clip: With the new pocket clip, the flashlight allows for deeper pocket carry and effortlessly goes unnoticed due to its compact design.
● Hands-free Use: Simply clip it onto a hat brim and you can use it as a convenient headlamp.
Olight Oclip Clip Light with White and Red Light
Price: CAD$39.95
● Dual light sources: White light for daily use and red light for night vision. The beacon mode in white light and the red blink mode ensure that users stay visible in critical moments.
● Multiple ways to carry: The versatile clip enables users to clip, hang, or magnetically attach the light to iron objects. It has extensive application scenarios, such as hiking, providing fill light for photos, cycling, reading, and safety warnings.
● Durable clip: The durable clip has passed 10,000 cyclic tests, overcoming the shortcomings of metal fatigue and deformation found in traditional back clips. It provides a more stable grip and can clamp objects up to 14mm thick.
● Lightweight and Compact: Weight: 1.06oz / 30g; Length: 1.91in / 48.5mm; Width: 0.83in / 21mm.
Flashlights Under CAD$100
Olight Perun 2 Mini LED Rechargeable Headlamp
Price: CAD$87.95
● Tiny but mighty: As small as your thumb but boasting a max output of 1,100 lumens.
● Red light: Providing quality light while not impairing your night vision and perfect for use as an emergency warning signal at night.
● Multifunctional use: Use as a Handheld EDC flashlight, or as a headlamp with the upgraded headband! It can even magnetically attach to any iron surface to be used as a work light.
● Tri-color power indicator: Three colors accurately indicate the remaining power. (Green:>60%, Orange:60%~10%,Red:10%~5%, Flashing Red:<5%)
● Upgraded headband: The contact area between the headband and the skin has been reduced, making it more comfortable and lighter to wear.
● Magnetic charging: Equipped with a USB magnetic charging cable for an easy and fast charging experience.
Olight Baton 3 Pro 1500 Lumens Rechargeable Flashlight
Price: CAD$93.95
● Brighter & Longer Runtime: Max 1,500-lumen output, 175-meter throw, and 120-day runtime make it perfect for indoor tasks, outdoor activities, and extended work use.
● 3.99in Long, 3.63oz Weight: Palm-sized with widened and lengthened two-way clip, placed in pockets or bags, it is the ideal EDC flashlight without sacrificing space.
● Larger Button, Unique Texture: 56% larger area than the previous generation button, provides an easier operation. Upgraded body knurling increases anti-slip while bringing a tighter grip.
● Fast Charging & Easy to Store: Fully charged in only 3.5 hours with the MCC3 USB magnetic charging cable. The included L-shape stand, which can be stuck anywhere, makes it easier for you to store the flashlight after use.
Flashlights Under CAD$150
Olight Arkfeld Pro Flat EDC Flashlight with LED Light UV and Laser
Price:CAD$134.95
● Versatile 3-in-1 EDC: Olight's FIRST rechargeable flashlight that combines 1,300lm white light, 900mW UV light, and Class 3R green laser, offering versatility for a wide range of applications.
● Pro White Light & Green Laser: White light for daily illumination, laser for pets toy / presentation, and the white light and laser can work in tandem for providing targeted point plus overall brightness.
● Extreme UV Experience: Strengthened 900mW (365nm) UV light, purer and more professional, nothing invisible to the naked eyes, makes stain/pets urine detection a breeze.
● Exquisite Design for Elegant You: Hold the flat and sleek body comfortably or easily carry in a pocket; switch lights by effortlessly rotate the intuitive circular selector.
● More Capacity, More Runtime: The Pro edition is supported by 1500mAh Lithium Polymer Battery, increased 42.9% from previous Arkfeld, max runtime of 11 days with five-level indicator, kicking your power anxiety out.
Olight Baton 4 Powerful EDC Flashlight 1300 Lumens
Price: CAD$87.95~CAD$134.95
Baton 4 - Ideal for EDC:
● Mini Outside, Mighty Inside: Almost shorter than your index finger. The Baton 4 provides maximum 1,300lm output and 170m throw, and can back you up for up to 30 days.
● Easier Operation & More Intuitive: The new metal switch offers improved ease of use and durability, while the indicators are microperforated by laser to visually show you the brightness and power levels.
Baton 4 Premium Edition - One Case, One Universe:
● Multi-functional Companion: Powered by a 5000mAh battery, the case can fully charge the Baton 4 flashlight 5 times, giving the flashlight a max runtime of 190 days. It can also charge your mobile devices for emergencies with its Type-C port.
● All Things Done With A Press: The digital display button on the case shows the remaining power; just press the button to light up the flashlight directly, and long press to achieve stepless dimming, allowing simultaneous charging and lighting in your hand.
● Home For Five Lights: The case is fully compatible with Baton 4 and Baton 3 and supports storing and charging the S1R II, Perun Mini, and Perun 2 Mini.
If you have a limited budget and consider yourself a newbie to flashlights, the Olight is definitely a great choice.
Why Buy From Us?
Not only does it provide a 30-day worry-free return service,
And it also comes with a Hassle-Free warranty.
More importantly, you will enjoy the surprises Olight continues to provide fans, such as irregular birthday, holiday, New Year, wedding anniversary gifts, etc. These are additional services provided by Olight to customers, making you feel more assured after purchasing and making the use process more enjoyable.
