As we always mention, a “ specialist only masters his own field” A cell phone camera is no substitute for a camera, and a cell phone flashlight is no substitute for a flashlight. Whether you're hiking, checking your electricity meter, or in an emergency, you may need a more powerful light source than a cell phone flashlight. Carrying a mini flashlight with you will make your way much easier.
What are the advantages of the best mini flashlights?
Tiny Size
Long Endurance
Powerful Lumen
Waterproof and Dustproof
Portable, No Burden to Carry
Robust and Reliable
Considering the list above, we have listed some of the best Olight mini flashlights for every day carry: Imorse, I3T, I3T plus, I3E, Imini, Gober,I1R2 Pro.
Olight iMorse-An exclusive, commemorative Morse Code light created just for O-fans.
iMorse keychain flashlight, 180 lumens can run for 23 minutes, 5 lumens can run for 12 hours; Influenced by Morse code, we invented Imores. An exclusive commemorative Morse code light created exclusively for O-fans. The new iMorse comes with a special Morse code message that can be decoded using the key card included in the package. The CSP LED with TIR optical lens has a maximum output of 180 lumens at 48m.
It adopts the new USB-C interface instead of the old Micro-USB interface. It is more convenient for charging. A built-in 130mAh lithium-ion battery keeps the light running for up to 12 hours. With a simple turn of the head, the user can turn the light on or off and switch the output.
Olight I3T EOS Ultra-thin mini Flashlight
Small but powerful:
With its slim design and exceptionally bright output, the Olight I3T EOS LED flashlight is the ultimate EDC illuminator! This compact flashlight is only 3.5 inches long and comes with a convenient two-way pocket clip, making it easy to carry in your pocket or bag wherever you go! Despite its small stature, the I3T EOS is capable of emitting a 180-lumen beam that can project nearly 200 feet, more than enough for most everyday tasks.
Ergonomic and stylish:
Every inch of the I3T EOS is designed to be as ergonomic as possible to provide the best user experience. The powerful light works on just one AAA battery (included), making it one of the brightest single-cell AAA flashlights on the market, and it's super easy to replace. Tail switch buttons make one-handed operation simple and effortless. The i3T body is made of aluminum alloy, which is incredibly impact-resistant and water-resistant, so it's safe to use anywhere. The body even has a unique spiral knurling that catches the eye and provides a comfortable and secure grip.
Highlights:
1.5m drop resistance and IPX8 water resistance
Small but compact body
Stylish spiral knurled envelope provides a firm grip
TIR (Total Internal Refraction) lens provides a smooth, evenly dispersed beam
Tactical tail switch allows for instant and full activation
Dual-sided removable pocket clip for easy portability
Olight i3T Plus Mini Flashlight
The Olight i3T Plus is a flashlight that is convenient for everyday carry and powerful. Its slim construction is matched to an output of 250 lumens, making intense tasks a breeze. The i3T Plus even offers multiple modes capable of reducing power down to 15 lumens output to save battery power.
NOTE: The Olight i3T Plus will output 250 lumens high for 1 minute, then automatically switch to 100 lumens output with a 480 minute runtime.
Designed for Convenience:
The rear anti-skid switch is easy to operate with one hand and can be used quickly when needed. The two-way pocket clip provides multiple carrying options from backpack to waist belt and completes its function with double helical knurling to establish a secure and comfortable grip.
Highlights:
Multiple brightness settings of 250, 100 and 15 lumens
Included two-way pocket clip provides multiple carrying options
Slim and stylish with double helical knurling to prevent slipping
Tail switch and light weight make one-handed operation a breeze
IPX8 water and impact resistant up to 2 meters
Olight I3E LED Keychain Mini Light
The perfect gift for any occasion, the Olight I3E EOS is a slim, stylish keychain light with backup LED power. I3E lamps can reach lighting powers up to 90 lumens. Enhanced with a TIR lens, this light's beam can travel up to 44 meters, making it an ideal range for everyday use - outdoors or indoors!
The people at Olight approach each new product with the same excitement and determination to make the best flashlight you've ever used. The I3E EOS is built to last, with a 1.5-meter drop-resistant, durable aluminum body. The light is sealed and rated IPX-8 for water resistance, making it weather-resistant in all conditions, even fully submersible. It's not just a key light, it's an Olight.
Highlights:
Small and portable body
Stainless steel key ring, key chain not included
TIR lens for maximum light output
Easy-to-use twisted interface
A variety of colors are available
Olight iMini LED Keychain Mini Flashlight
Mini but mighty:
Using the Olight iMini keychain light has never been easier! With a maximum output of 10 lumens and a throw distance of 10 meters, this light is perfect for your simple needs at home or when walking at night. Its single output makes it very easy to use and a great lighting compliment!
Upgrade magnet:
This keychain light is designed with a magnetic cap and base, giving it multiple functions. By separating the two, the iMini will activate instantly, giving you quick access to lighting wherever you go! The magnetic base also lets you mount this light on any flat metal surface so you can work comfortably with both hands.
Highlights:
10 lumens max output at 10 m beam distance
Designed with a single output mode for an easy-to-use user experience
Features a magnetic base and lid for near-instant access to lighting
Magnetic base allows you to mount it to any flat metal surface for hands-free use
Made of aluminum alloy for increased durability
Use a replaceable LR41 coin cell battery
Gober Safety Night Light
1.5 inches in length, weighing only 16g, about 0.5 ounces; 3 high-performance LEDs, 4 different color settings (red, green, blue, and white), built-in rechargeable Li-ion battery with 28 hours max runtime. No matter by clipping it to your backpack or your belt or attaching the light to your pet's harness or a lead, it operates well as a safety light or signals light, suitable for hiking, running, dog walking, and more. Only one switch control for one-handed operation. Effortlessly clipped to any MOLLE system gear using the backpack clip. USB-C charging port makes it fully charged in about 1.5 hours.
Olight I1R2 Pro EOS Mini Flashlight
The i1R 2 Pro is the upgraded version of i1R 2 EOS, Olight's popular rechargeable keychain flashlight. The high-performance CSP (chip scale package) LED, paired with a TIR optic lens, generates a soft, well-balanced beam of 5 lumens or 180 lumens. Users can turn the light on/off and switch outputs with a simple twist of the head. Powered by a larger built-in 130mAh Lithium-ion battery, it runs up to 12 hours. The flashlight adopts the new USB-C port instead of the old Micro-USB port, which makes charging easier. The aluminum alloy body makes this small light extremely durable. Only 51.3mm/2.02in long with a weight of only 22g/0.78oz, it is the perfect addition to your keychain.
Highlights:
High performance LED, paired with a TIR optic lens, generating a soft, well-balanced beam of 5 lumens/180 lumens.
New USB-C port allows for a full charge within 100 minutes without disassembling the light or fiddling with the cable.
Only 51.3mm/2.02in long with a weight of only 22g/0.78oz, almost unnoticeable on your keychain.
Turn the light on/off or switch outputs with a simple twist of the head. Twist it slightly to turn it on for 5 lumens, a bit
more for 180 lumens
