You may have heard the term "tactical flashlight" before. But tactical flashlights have long been used outside of the military and police.
But what does a tactical flashlight mean? If you've ever wondered what a tactical flashlight is, what it's used for, and what to look out for when buying one, you'll find the answers to your questions in this article.
Tactical Flashlight - What Exactly Is It?
The definition of a tactical flashlight is relatively simple: it is a very rugged portable flashlight with a very powerful beam and some special features, such as offensive head and tail tactical switches, etc.
Tactical flashlights are widely used by the police and military, and are also popular with hunters. However, their use is not limited to the police, military and security services. At the same time, outdoor enthusiasts are using them more frequently.
Tactical flashlights come in different designs and have different functions. But what do you need to pay attention to when buying a tactical flashlight?
What's the Difference Between Tactical Flashlights?
Tactical flashlights have some characteristics that differ from traditional flashlights. On the one hand, it's very durable and its beam is strong enough to be seen from a distance.
In addition, the tactical flashlight also has some practical functions, which can be used for self-defense or emergency situations. Tactical flashlights are very versatile.For example, it can be used to find your way in the dark or give a signal. But tactical flashlights are also used for finding injured people or for repair work in cramped and dark rooms. Many models are also water resistant, so they can also be used in bad weather.
Advantages of Tactical Flashlights
A good tactical flashlight has many characteristics. So, if you're planning to buy a tactical flashlight, make sure to include the features mentioned here:
Sturdiness
One of the biggest advantages of a tactical flashlight is its ruggedness. These lights are usually made of high-quality materials such as aluminum and have a strong housing. This makes them very strong and durable. Therefore, tactical flashlights are the best choice in harsh environments.
Emergency hammer
A tactical flashlight with a serrated head that doubles as a weapon in an emergency. You can use it to smash car windows or glass if you need to get out of trouble.
Water proof
A good tactical flashlight is also waterproof. What good is the best defense if it breaks when it rains heavily or falls into the water? When buying, make sure the bulbs are waterproof and can withstand extreme temperatures.
Light weight
Tactical flashlights should also be as light as possible. Although it will be larger than an EDC flashlight, it shouldn't be too heavy or you lose a lot of convenience. Ideally, for example, you could carry a tactical flashlight on your belt without it becoming a burden.
Ease of use
If the worst happens, you have to react quickly. You won't be able to do this if you have to fiddle with switches. That's why it's critical for a tactical flashlight that you can operate it intuitively with one hand, if possible.
Many models of flashlights have a switch on the tail that is very easy to operate, even while wearing gloves. So make sure that the operation of the light is as easy and intuitive as possible for you so that in the worst case you can operate it quickly.
Glare
The most important thing about a tactical flashlight is to have a powerful beam. A tactical flashlight should have the strongest beam possible to ensure you can see far. Tactical flashlights use high-performance LEDs that typically produce up to 1,000 lumens of brightness.
Strobe mode
Strobe mode is a special feature of tactical flashlights. In this mode, the lights come in short flashes, so the attacker's eyes are unable to adjust to the flashes and have a brief blinding effect. During this time, you can gain the opportunity to escape and keep a certain distance from the attacker.
Dimming function
In addition to the described features, many tactical flashlights offer dimming options. This is useful if you're hiding somewhere in an emergency and don't want to be noticed. By dimming, you narrow down the range of light so it doesn't give away your location.
For example, you can read military maps unobtrusively with only 0.5 lumens, keeping your bearings unnoticed.
Distress signal
Some tactical flashlights are capable of sending out an SOS signal. If you need help in an emergency, you can use lights to signal.
This can increase your chances of being rescued, and the light will send out a distress signal repeatedly, allowing you to focus on other things.
Battery indicator
Depending on the situation, you need to be able to rely entirely on your flashlight. A flashlight that suddenly runs out of charge in a dangerous situation is of little use. So make sure the flashlight is as durable as possible and has a battery indicator light. So you always know when the bulb needs to be recharged and avoid unpleasant surprises.
In conclusion
Tactical flashlights are no longer just for the military and police. Today, you can also use tactical flashlights for outdoor adventures and more. When shopping for a tactical flashlight, make sure it has a strobe mode, dimming function and charge indicator, as well as features like shock and water resistance so you can handle the unexpected.
