Canadian wilderness camping demands both preparation and resourcefulness. Whether you are trekking through the dense woods of Algonquin or surviving a freezing night in the northern boreal forest, mastering the right fire-starting techniques is a literal lifesaver. Among the most efficient methods is the swedish torch, also known as the swedish candle fire or fire torch. This classic bushcraft fire method provides a self-sustaining, wind-resistant heat and light source that is perfect for cooking and staying warm in harsh environments.
This comprehensive canadian camping guide teaches you exactly how to select the right wood, build this efficient fire step-by-step, and pair your setup with reliable outdoor lighting gear to ensure you master the night.
- What Is a Swedish Torch? A Brief History of the Canadle
- Tools & Materials You'll Need
- Step-by-Step: Building & Lighting a Swedish Torch
- How Long Does a Swedish Torch Burn?
- When the Fire Fades: Essential Camp Lighting to Pack
- Safety, Regulations & Leave-No-Trace in Canadian Parks
- FAQ
- Conclusion: Master the Fire, Master the Night
The swedish torch traces its origins back to the Thirty Years' War in Europe. Swedish soldiers needed a way to keep warm and cook food without burning through their limited wood supplies. They developed a method of utilizing a single standing log, making vertical cuts down the trunk to allow internal combustion. This design acts as a natural stove, drawing oxygen from the bottom slits and projecting intense heat upward.
Why It Works So Well in Snow & Wet Conditions
For anyone practicing boreal forest survival, the swedish candle fire is a game-changer when ground conditions are poor. Traditional campfires require dry ground or a built-up platform to keep the kindling from absorbing moisture from damp soil, ice, or deep snow.
Because the flame of a swedish torch is contained entirely inside the log, it remains elevated off the wet ground. The outer bark and wood serve as a windbreak, protecting the internal coal bed. Furthermore, as documented in technical biomass research by Forest Research, the internal chamber heats up and dries surrounding timber from the inside out, optimizing thermal dynamics and lowering internal moisture thresholds to ensure high combustion efficiency even in damp climates.(Source: Forest Research)
To construct this efficient camp stove, you must gather the proper tools and select the right organic materials.
Choosing the Right Log (Species, Dryness, Size)
Not all wood is equal when preparing a bushcraft fire method. For a successful burn, look for logs with the following characteristics:
- Dryness: Use well-seasoned dry wood. Wet or green wood will produce excessive smoke and struggle to stay lit.
- Species: Conifers like pine, spruce, or fir are ideal because their resin helps ignite the fire quickly. Hardwoods like birch or maple burn longer and hotter but are more difficult to light.
- Size: Aim for a log that is roughly 12 to 18 inches tall and 8 to 12 inches in diameter with a flat, level top and bottom so it stands securely.
Safety Gear & Fire Safety Basics
Always wear sturdy work gloves and eye protection when cutting or splitting wood. Keep a bucket of water or a shovel with dirt nearby to manage any stray embers. According to foundational woodland fire management protocols outlined by Parks Canada, keeping campfires small, controlled, and within designated fire containment structures is mandatory to prevent runaway blazes. Ensure the surrounding area is cleared of dead leaves, pine needles, and dry brush before igniting your log.(Source: Parks Canada)
There are three common ways to construct a swedish torch depending on the tools you have on hand in the backcountry.
Method 1 — The Traditional Chainsaw Cut
If you are car camping or have a chainsaw available, this is the quickest method:
1. Stand your dry log upright on its flat base.
2. Make a vertical cut down the center of the log, stopping about 4 to 6 inches from the bottom to keep the base intact.
3. Rotate the log 90 degrees and make a second vertical cut, creating an "X" pattern from the top.
4. For larger logs, you can make a third cut to divide it into six equal pie-like wedges.
Method 2 — The Split-Log Method
If you only carry an axe or a heavy survival knife for batoning, use this manual method:
1. Split the log completely into four quarters.
2. Shave down the inner corners of each quarter to create a small central chimney space when reassembled.
3. Place the pieces back together in their original log shape.
4. Secure the bottom tightly using strong wire or wet, pliable roots to maintain structural integrity under heavy thermal stress.
Method 3 — The Bundled Log Version
If you do not have an axe or chainsaw, you can easily gather small limbs to replicate the design:
1. Gather 4 to 6 dry, straight limbs of similar length and thickness.
2. Bind them tightly together vertically using metal wire or natural rope at the base.
3. Stand the bundle upright on flat ground.
Getting the Fire Started (Tinder & Kindling Tips)
Once your log structure is secured, it is time to light it:
1. Pack dry tinder (birch bark, dry grass, or commercial fire-starter) into the top-center cracks of your log.
2. Insert thin kindling twigs vertically into the slits, leaving enough space for oxygen to flow freely.
3. Ignite the tinder from the top to trigger downward draft combustion, turning the log into a self-feeding, highly efficient vertical stove.
On average, a standard-sized swedish torch (15 inches tall and 10 inches wide) will burn consistently for two to five hours.
The burn time depends on several factors:
- Wood Density: Hardwoods like oak burn slower and last longer than softwoods like pine.
- Wind Speed: High winds supply more oxygen, causing the fire torch to burn hotter but consume fuel much faster.
- Cut Depth: Leaving a thicker base keeps the log stable and structurally sound, maximizing fuel efficiency and extending the overall life of the active fire bed.
Once the internal walls burn through completely, the log will eventually collapse outward into a bed of hot, long-lasting coals, which are perfect for roasting food.
While the glowing embers of your swedish torch provide a rustic ambiance, they cannot replace the high-intensity illumination needed for camp safety, navigation, and emergency signaling. To protect yourself and your group during late-night hours in unpredictable Fall weather, equipping your pack with elite illumination tools is non-negotiable.
Olight Warrior 3S — For Perimeter & Wildlife Safety
When the forest goes completely dark, a long-range tactical beam is essential for spotting wildlife and checking the perimeter of your camp. The Warrior 3s 2300 Lumens Powerful Flashlight is built specifically for these rugged situations.
This high-performance tactical light delivers a blinding 2,300 lumens with a beam throw of 300 meters. Its integrated proximity sensor automatically dims the output if it detects obstructions, preventing thermal overload while offering up to 55 days of runtime in moon mode to guarantee your safety.
Warrior 3S (2300 Lumens)
Key Specs: Delivers up to 2,300 lumens with a 300-meter beam distance, featuring a dual-switch layout and proximity sensor protection.
Add to Cart →Olight Baton 4 Premium — Ambient Camp Light
For setting up your tent, organizing your pack, or reading inside your shelter, you need a compact, ultra-portable light source. The Baton 4 Powerful Edc Flashlight 1300 Lumens packs serious power in a pocket-sized form factor.
The Baton 4 delivers 1,300 lumens of output. The Premium Edition features a multifunctional charging case equipped with a 5000mAh battery, capable of recharging the flashlight five times for a total extended runtime of up to 190 days, while doubling as a reliable power bank to keep your vital electronics charged.
Baton 4 (1300 Lumens)
Key Specs: Max 1,300 lumens output in an ultra-compact body, designed for ultimate everyday carry convenience and performance.
Add to Cart →Olight Perun 3 — Hands-Free for Cooking & Setup
Whether you are preparing ingredients to cook over your swedish candle fire or batoning wood in the dark, you need both hands free. The Perun 3 Headlamp is the perfect hands-free rechargeable camp torch.
Offering up to 3,000 lumens of cool white light and an integrated red light mode to preserve night vision, the Perun 3 is incredibly versatile. It can be worn securely as a headlamp or magnetically mounted to metal surfaces, projecting bright, dependable light exactly where you look.
Perun 3 Headlamp
Key Specs: Dual-purpose right-angle headlamp and handheld light, delivering powerful illumination and hands-free convenience.
Add to Cart →Safety, Regulations & Leave-No-Trace in Canadian Parks
When camping in Canada, preserving the natural landscape is of utmost importance. Always adhere to the following wilderness guidelines:
- Check for Fire Bans: Boreal forests are prone to wildfires. Always consult local park authorities (such as Ontario Parks or Parks Canada) for active fire bans before igniting any flame.
- Elevate on Non-Combustible Surfaces: If possible, place your log on a flat rock or sand bed to prevent scorching the soil underneath.
- Pack It Out: Once your swedish torch burns out, thoroughly douse the coals with water, stir the ashes, and ensure the spot is cold to the touch. Pack out any leftover charred remains to leave no trace.
Can I use green wood for a swedish torch?
Can you cook directly on top of a swedish torch?
How do you extinguish a swedish candle fire safely?
The swedish torch is an elegant, reliable, and highly efficient bushcraft fire method that every Canadian outdoor enthusiast should master. Its elevated design keeps your fire safe from wet snow, while its flat top provides an instant cooking surface. However, a great fire is only half the battle when surviving the wilderness. Gear up for your upcoming Fall camping trips today—don't let the dark catch you unprepared. Secure your high-performance flashlight and conquer the backcountry with absolute confidence!
